Ben75
Newbie
Message 1 of 11
Trouble activating Smart Hub
I’ve just moved into a new build house which has a Huawei modem fitted in a cupboard under the stairs and which should be set up with BT broadband. I’ve received a Smart Hub that contains a red ethernet cable. The instructions with the Smart Hub say to connect one end to the WAN socket in the hub, and the other to port one in the modem. All of the sockets of the modem already have wires in them so I don’t know where to connect it.
I contacted BT who told me the Smart Hub doesn’t need to be connected to the modem. It seems that it can be connected direct from the broadband socket to a wall socket. I purchased an RJ11 cable and tried it with several wall sockets but none work and the hub keeps flashing purple.
I’m unsure which method I should be using (WAN to modem or broadband socket to wall), and can’t figure out how to do either. Can anyone help?
10 REPLIES 10
Message 2 of 11
Re: Trouble activating Smart Hub
Where does the cable in port one of the modem go to? Possibly an Ethernet patch panel.
Sage
Sage
Message 3 of 11
Ben75
Newbie
Message 4 of 11
I’m unsure which is port one of the modem. I’ve tried to take a photo but the file is too large to upload. There is a grey cable which runs to a wall socket and a phone line cable which runs into a wall socket. A third cable goes through the wall (there is something like brush fibres which is disappears through. There’s also a cable which is attached to a plug that is plugged into an electrical socket. The other cable slots seem to have wires which connect from one part of the modem to another part of it (it’s not easy to tell as there’s a casing over it but it looks like the modem is in two parts)
Also there are five lights on the modem. The ones saying TEL1, PON, and POWER are on, whilst the ones saying PORT1 and LOS aren’t
Sage
Sage
Message 5 of 11
Port1 light will illuminate when connected to the hub via the ethernet port. LOS (loss of signal) should remain unlit.
Message 6 of 11
Shrink the photo and upload it.
There is a modem and battery back up unit.
The Hub should connect to the second port from the left and probably connects to an RJ45 wall socket to extend it to another part of the house. You can either unplug this lead and connect your hub or find out where the RJ45 socket is cabled to and plug the Hub in there.
The leftmost connector is the optical lead and should have a green cover, DO NOT TOUCH THIS CONNECTOR.
For older installations
Sage
Sage
Message 7 of 11
@licquorice That's the original type ONT you've  posted. See photo in my post.
Sage
Sage
Message 8 of 11
BTW, the ONT no longer comes with battery back up.
Ben75
Newbie
Message 9 of 11
Okay, so port one has the grey cable. Have unplugged it and plugged in the red cable and now have Internet. Thanks!
Message 10 of 11
Glad you got it working
