gurka
Message 1191 of 1,731
Re: UPGRADE OF 40MB TO 80MB SPEEDS ?
try restartung both the hh3 and or modem
ady199
Message 1192 of 1,731
I dont use a HH3 as BT have sent me 4 now and not one of them work properly, so I use a Netgear WNDR3700.
I've re-booted both the Modem & the router and now get this:-
I've tried to do the BT speed test but that failed on the Results page, so I've tried to re-run it and its says I have to wait another hour to do another test
Any suggestions??
ady199
Message 1193 of 1,731
Finally managed to get a result from the BT speedtester:-
I was quoted as 60.2 Mbps download
Help!!
McGrath1982
Expert
Message 1194 of 1,731
Speeds are here now looking good BT
http://www.speedtest.net/result/1891476748.png
nayan89
Message 1195 of 1,731
http://www.speedtest.net/result/1891489793.png
lol I signed up for an increase not a decrease, what's happening :S The profile speed in my bt page is still the same too
D-ave
Expert
Message 1196 of 1,731
Help!!
Speedtester diagnostics is broken (I am getting 6 to 9Mbps from it lol), it's only any use for getting your profiles.
Use the beta tester http://www.speedtester.bt.com/beta/speedtest-remote.jsp
I am finding that even speedtest.net is variable, the ping selection doesn't pick the fastest server and it all depends on which server I choose whether I get 40Mbps, 68.5 or anything in between. BT Beta tester gives 70.5 Mbps which is close enough to my profile (72.03) to be accurate, I think.
sahotaquack
Message 1197 of 1,731
Was getting the full 38 and 10, quoted 62 and 20 but i'm currently getting 42 and 15 which I do not think was worth the recontract as I could have got a few quid knocked off when renewing in a few months. Anyone know if the is a cooling down period to cancel the re contract?
Message 1198 of 1,731
Three things to check when running speedtests.
1) You are using a wired connection ideally on a gigabit link rather than 100mb/s - wireless connections are unlikely to deliver speeds up to 80mb/s even if they are n. I know in theory they can but in practice they often don't
2) You are using a speed tester that can deliver the speeds the Nameso BB Max at http://www.speedtest.bbmax.co.uk/ can (just gave me 79199 kb/s down and 14739 up). Not all speed tests can even speedtest.net is struggling to give me over 10Mb/s uploads.
3) Your PC is reasonably modern and powerful.
Otherwise any results you get are likely to be false and measuring the slowest part of your system
sahotaquack
Message 1199 of 1,731
1. Tried it wireless, wired and used the gigabyt port and still same results.
2. Used numerous different speed testers and near enough showing the same
Message 1200 of 1,731
OK my line has been upgraded and as I can see the sync speeds on my Draytek router I know that the cabinet is delivering full speeds. The screen shot below shows the figures. The estimate I was given was 63Mb/s down 20Mb/s up according to the engineer it is just over 300m to the cabinet. As posted above it seems to be working in practice a 1GB test file came down at 8MB/s give or take.
