loudgraham
Message 1241 of 1,731
Re: UPGRADE OF 40MB TO 80MB SPEEDS ?
one week to go until i get infinity for the first time 🙂 jumping from 5mb to 45mb , highest i can get on my exchange (rottingdean A ).
just wondering if anyone has managed to get a discount on infinity .
Message 1242 of 1,731
You'll only get a discount when you get to the end of your initial contract and agree to take out a new term I think.
ady199
Message 1243 of 1,731
Mine still shows:-
Why??
MartynIT
Message 1244 of 1,731
Hello all. mine upgraded last night was told 61mb but my speed tests only showing 40. ip profile is 76,
I have rebooted the modem and router a couple of times. MyBT still shows 39d 9.5u
any help would be great.
Martyn
McGrath1982
Expert
Message 1245 of 1,731
Stil saying 38Mb and 9.5Mb on MY BT but i have bin upgraded
Unlimited usage
  • Up to 38Mb download speed
  • Up to 9.5Mb upload speed
  • Advanced security software
  • Parental controls
  • Unlimited WiFi minutes
  • 24/7 support
http://www.speedtest.net/result/1891761141.png
sahotaquack
Message 1246 of 1,731
I was estimated 62 down and 20up and i am getting 42 down and 13 up
Paul1360
Expert
Message 1247 of 1,731
Well my uplift happened at 0200am this morning:-
Before and after, upload is a bit lower than I though but it's up 7ish, really happy with the down speed it's higher than 69.5Mb from wholesale checker and 3mb higher than what the form stated. I would really love to know what I've done wrong to the BT tester as it don't like me 1 bit, IP Profile of 77.43Mb and it returns 15Mb down, Up profile 20Mb returns 15.89Mb, beta tester gives me 75.04Mb. Crazy results. Just thinking that a year ago was getting 1.5Mb D/L & 1.0Mb U/L. Anybody know why my smartphone ipad2 and Tab 10.1 have stayed about the same speed as before 30Mb ish??
Thank you BT.
iechyd da
Dean78
Message 1248 of 1,731
Mine also still shows the old speeds in My BT page. Something to worry about? or is it just delayed. The order tracking also now has no details at all, I'm guessing because its now closed and complete on the system.
loudgraham
Message 1249 of 1,731
thanks for the reply, lucky i got a 12 month contract then 🙂
Message 1250 of 1,731
Thank you BT.
iechyd da
Probably limited by wireless speeds even good n signals frequently do not go much above 40 Mb/s in the real world
