alz123
Message 1201 of 1,731
Re: UPGRADE OF 40MB TO 80MB SPEEDS ?
hi all
http://www.speedtest.net/result/1891544050.png
was was told 58
well pleased
Message 1202 of 1,731
@sahotaquack wrote:
1. Tried it wireless, wired and used the gigabyt port and still same results.
2. Used numerous different speed testers and near enough showing the same
You certainly have removed most of the variables - not sure if you can switch back but contact the mods and ask. I think the estimates are based on known lines with similar characteristics not your line as such so a few lines will perform worse than predicted whilst most will meet or beat the estimates its down to luck of the draw.
philt1808
Message 1203 of 1,731
I was getting improvement in upload but not download speed.  Have just restarted the modem and HH3 and now getting:
I was quoted 66/16 so I'm more than happy with this.  Latency has gone up slightly from 5ms to 15ms but this might settle back down.  All in all - great improvement from the 2Mbps I was on in early Feb!! Smiley Very Happy
nayan89
Message 1204 of 1,731
I've gone through all the possible problems but I'm still getting 28mb/5mb. Last night I was on 38mb/8mb. The order says it's complete but my speed hasn't changed in the My BT section.
PC is fairly new too (i5 2500k - 8gb ddr3 - 120gb ssd)
prt32
Message 1205 of 1,731
Much better download than it was told, but much slower upload that quoted, but hey can't have it all.
Thanks BT nice work so far
twitch
Message 1206 of 1,731
I was qouted 60/20, and getting results around the 74/15 mark.
So well chuffed.
One thing I noticed was that I had to disable my AV (kaspersky) on speedtests to show better results.
Though on downloading large files from newsgroups it's a steady 8.95MB/s with or without the AV running.
http://www.speedtest.bbmax.co.uk/results.php?t=1334296621&v=15533245
Message 1207 of 1,731
If the tests are by a wired connection rather than wireless something is wrong. Try to get your IP profile from the BT Speedtester if nothing improves probably query it with the mods but they are likely to be a little bit busy I suspect.
Nice PC specs very similar to my own which goes like extretia off a digging implement.
sahotaquack
Message 1208 of 1,731
Il find out, il give it untill tomorrow and hopefully it will change. Tbh honest I'm very happy with my 38mb and anything extra i see as a bonus....anything is better than the 0.2 ADSL I was stuck on before lol
Message 1209 of 1,731
There was a known issue with Ookla tests like Speedtest.net with Kapersky but I thought it had been fixed but clearly it hasn't.
nayan89
Message 1210 of 1,731
Hi thanks for your reply. I am using wired connection, I've even tried plugging the white openreach modem directly to my modem but no luck. If there's no change in a few hours I'll try putting my old HH3 back in as I'm using a netgear wrn3500 at the moment, but this shouldn't be a problem?
Just ran the BT speedtester to see my profile:
http://img171.imageshack.us/img171/8861/btspeedtester.png
Very weird...
Also yeah, just upgraded the system a couple of months back, it flies! 😄
