Message 1231 of 1,731
Re: UPGRADE OF 40MB TO 80MB SPEEDS ?
6.7MB/s equals 53.6 Mb/s so far from dusty for a real world example.
Moderator
Moderator
Message 1232 of 1,731
Hi Walkerx,
If the upgrade appears stuck can you try resetting the hub / modem. If that doesn’t help drop me an email with the details. You’ll get the “contact us” form in the about me section of my profile.
@Ady199 I can check it for you as well. Drop me the details and I’ll take a look.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
ady199
Message 1233 of 1,731
Thanks for the replies - My IP Profile is set at 53.54Mbps so I'm getting the correct speed.
However I was quoted 60.2Mb download (shown on the BT Infinity Checker) - Is there anyway to get my IP profile increased?
Thanks in advance
Moderator
Moderator
Message 1234 of 1,731
Hi Cheese9000,
Did the upgrade complete for you yet? Let us know how you're getting on.
Cheers
David
Kudos”Kudos”
Dean78
Message 1235 of 1,731
My upgrade has taken place at some point in the morning.  I have gone from 40meg to 50meg down but the upload is still at 10.  Not too bad considering the checker estimated I would get around 32 AFTER the upgrade lol.
Message 1236 of 1,731
Thanks in advance
The 60.2 is the connection speed, so you're not too far off with a profile of 53.54. Your connection will be about 55meg.
There could be several reasons for the slightly lower than estimated speeds. Crosstalk, quality of cable to the cab, material of the cable to the cab, number of joints etc.
To be honest, your speed is still awesome and there's nothing you can't do with it 🙂
kitkat388
Message 1237 of 1,731
Hi there .
Can anyone tell me has their MyBt account broadband section updated to 76/19 after the upgrade ? Coz mine stay the same as before 38/9.
ady199
Message 1238 of 1,731
@DavidM - Hi, details sent to you - Ref: 120413-*****
Cheese9000
Message 1239 of 1,731
Just restarted my modem... Speachless...
Message 1240 of 1,731
@kitkat388 wrote:
Hi there .
