Toddie1982
Message 1 of 13
Ultrafast 1 connection dropping every few days
Hi all
Had ultrafast via gfast activated on 26th March.
Have noticed that the cnnection to the network drops for a few seconds every couple of days. It only lasts a few seconds.
Only reason I noticed is I was wat hung Netflix and it paused so I checked router.
Seems to happen between 8pm and 10pm.
Is this due to the line DLM adjusting the line etc?
I am plugged into master socket in the test socket behind the faceplate. Line test is quiet when doing a quiet line test.
Never had this issue when I was with Sky broadband. Had FTTC with them too.
I know the first 10-14 days you can experience intermittent connection from the "what to expect In the first few days"
Stuart
12 REPLIES 12
Toddie1982
Message 2 of 13
Re: Ultrafast 1 connection dropping every few days
Product code:Smart Hub 2
Serial number:+091301+1837009064
Firmware version:v0.12.02.11078-BT
Firmware updated:Tue Mar 26 17:11:25 2019
Board version:R01
GUI version:1.53a 29_08_2018
DSL uptime:0 days,00 Hours14 Mins06 Secs
Data rate:29.165 Mbps / 159 Mbps
Maximum data rate:35.749 Mbps / 206.957 Mbps
Noise margin:5.4 / 7.3
Line attenuation:0.0 / 36.2
Signal attenuation:0.0 / 36.2
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:25.4 MB Uploaded / 263.2 MB Downloaded
Broadband username:bthomehub@btbroadband.com
BT Wi-fi:Activated
2.4 GHz wireless network name:BT-QMA66F
2.4 GHz wireless channel:Smart (Channel1)
5 GHz wireless network name:BT-QMA66F
5 GHz wireless channel:Smart (Channel40)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:On
MAC address:4C:1B:86:C8:31:CB
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22
Toddie1982
Message 3 of 13
:52:42, 05 Apr.DSL Link Up: Down Rate=159000kbps, Up Rate=29165kbps; SNR Margin Down=7.3dB, Up=5.4dB
20:52:40, 05 Apr.PPP: Sending PADI
20:52:34, 05 Apr.PPP: Starting PPP daemon
20:52:34, 05 Apr.WAN Auto-sensing detected port DSL WAN
20:51:49, 05 Apr.WAN Sensing Auto sensing Complete, interface selected
20:51:48, 05 Apr.WAN Sensing Auto sensing Running
20:51:47, 05 Apr.WAN Sensing Auto sensing Complete, interface selected
20:51:46, 05 Apr.WAN Sensing Auto sensing Running
20:51:46, 05 Apr.WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
20:51:45, 05 Apr.PPP: Stopped PPP daemon(0,1,5)
20:51:45, 05 Apr.PPP LCP Send Termination Request (User request)
20:51:45, 05 Apr.PPP: IPCP down
20:51:45, 05 Apr.PPP: LCP down
20:51:45, 05 Apr.DSL Link Down: duration was 427159 seconds
20:12:56, 05 Apr.Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLIC
Toddie1982
Message 4 of 13
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
HighLowHighLowVDSL Range A (Clean)8067201961.6Available----VDSL Range B (Impacted)8066201960Available----G.fast Range A (Clean)3303305044.9330Available----G.fast Range B (Impacted)3303305033330Available----
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand33030--Available----
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+Up to 4--3 to 5Available----WBC ADSL 2+ Annex MUp to 4Up to 13 to 5Available----ADSL MaxUp to 3--2 to 4Available----WBC Fixed Rate2----Available----Fixed Rate2----Available----
Observed Speeds
G.Fast
VDSL
Max Observed Downstream Speed (Mbps)310.76--Max Upstream Observed Speed (Mbps)42.88--Observed Date2019-04-05--
Other Offerings
Availability Date
VDSL Multicast------Available----ADSL Multicast------Available----G.fast Multicast------Available----
Premise environment
Status
Bridge TapUVRI--
Toddie1982
Message 5 of 13
To add....
I have reset and rebooted router too.
Toddie1982
Message 6 of 13
Any advice much appreciated
Sage
Sage
Message 7 of 13
Ring the FTTP team on 0800 587 4787. They are the only ones who deal with Ultrafast issues. The mods here cannot assist.
Toddie1982
Message 8 of 13
Thank you. Will do
Moderator
Moderator
Message 9 of 13
Thanks for taking time to let us know this is sorted @Toddie1982 . Appreciate you taking time to do that.
All the best
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
Toddie1982
Message 10 of 13
Unfortunately not sorted as still dropping g but was told that this cant be resolved through this forum.
