CarlG27
Message 1 of 16
Ultrafast Broadband
Hi,
I have just had Ultrfast broadband installed which works perfectly at the master socket.
I moved the hub to a different socket (while the engineer was still there) and this was connected using a filter to convert the RJ11 plug to a PSTN plug, the engineer stated that this would slow the speed down which I understood. He told me I needed an RJ11 to PSTN adaptor (or cable). I purchased an adaptor but this didn't work. Most cables I can find are basically telephone line extensions which use pin 2 & 5 at each end, I've spotted ones that use pins 3 & 4 at the RJ11 end and 2 & 5 at the PSTN end and others stating 4 wire straight or crossover.
So basically all I need to know is which of the above do I need to simply convert the RJ11 to PSTN?
15 REPLIES 15
Sage
Message 2 of 16
Re: Ultrafast Broadband
If your master socket has a Service Specific Faceplate (ie 2sockets, 1 broadband, 1 phone line) then it is pre-filtered and the broadband signal will not be sent to any other socket.
CarlG27
Message 3 of 16
Hi it is sent to the other sockets as the Openreach engineer did it for me.
Sage
Message 4 of 16
Then rather than looking for other cables just use a filter and connect as normal. Why didn't you just ask him to move the master socket? Why didn't he suggest it?
Sounds like you got a contractor install.
CarlG27
Message 5 of 16
That's what has been done but the additional filter drops the speed quite significantly.
As the Openreach engineer stated all I need is a RJ11 - PSTN adaptor however just want to know which option to go for as there are several.
Sage
Message 6 of 16
For the broadband signal the filter is a direct pass through, only the telephone side is filtered.
If you want to do away with the filter then get one of these from a well known auction site.Adaptor.jpg
Enter this in the search bar "rj11 to pstn male adaptor"
CarlG27
Message 7 of 16
That's what I bought and it didn't work yet the filter does. Could be just a faulty product I guess.
Sage
Message 8 of 16
Give the Ultrafast team a ring and tell them you are not happy with the install. The engineer should have moved the master socket for you. 0800 587 4787
Keep us updated on how you get on.
Message 9 of 16
Seems odd that the filter drops the speed.
You need pins 3&4 at the RJ11 end and 2&5 at the phone plug end. Polarity doesn't matter.
CarlG27
Message 10 of 16
He did offer to do that but, without going into detail, would have been messy.
In essence all I'm trying to do is use the existing telecoms internal wiring of the house as an extension lead rather than run one from the master socket to the Hub, all I'm now having trouble doing is matching the PSTN socket output into the RJ11 (pin 3 & 4) input.
I'll get it sorted one way or the other. Thanks for trying anyway.
