Longshanks
Message 1 of 66
Ultrafast Fibre Plus
Hi
Have been upgraded to “Ultrafast Fibre Plus”. (Only went into into EE Shop to get new iPhone for my son😡)
I’m not complaining (yet) as they saved us £20 a month on what we were paying for current Infinity contract and promise of greater speeds etc) The engineer is coming next week to set up, however I have two questions:
1. I’m terrified that the new Smart Hub will start generating the inevitable constant disconnections. To mitigate this, will I be able to keep my trusty Openreach modem in the set up? (Works v well with our current HH5)
2. They insisted this was FTTH species of Ultrafast. If this is so, I’m curious as the only new cable laid in street the last two years has been Virgin. Suggests this is more Gfast. What do you think?
65 REPLIES 65
brookheather
Message 2 of 66
Re: Ultrafast Fibre Plus
Enter your phone number or address into the DSL checker and you will see whether you have FTTP or G.fast availability. You won't be able to use your OR modem with G.fast.
https://www.dslchecker.bt.com/
Longshanks
Message 3 of 66
Thanks for quick response. DSL results quite difficult to interpret. There is a line which says     “ FTTP is available and an “ ONT” may be ordered? If FFTP is available, can I retain modem?
Sage
Sage
Message 4 of 66
No you cannot retain the Openreach modem on FTTP. The ONT is the modem and you be able to use your router of choice with it.
Longshanks
Message 5 of 66
Ok thanks again. Just to be clear then:
FFTP uses a modem, which is called the ONT.
Gfast doesn’t use a modem.
I was wondering, if I pm someone with details, could they check status of visit, FTTP, Gfast etc. Also, the speed quoted is 138mb. Is this more suggestive of Gfast??
Longshanks
Message 6 of 66
Meant FTTP.
Message 7 of 66
this is a customer help customer forum and your post does not go to BT
who is supplying your ultrafast - BT or EE?
Longshanks
Message 8 of 66
Hi
know this is Community forum, but thought there were BT staff patrolling, willing to pursue queries etc.
Ultrafast will be provided by BT.
Message 9 of 66
Correct
It does, but but your current modem isn't compatible. Not sure there are any standalone G.Fast modems available, G.Fast compatible devices are combined modem/routers.
Message 10 of 66
phone the FTTP team who also deal with G.Fast and see if they can help  08005874787
