Message 21 of 66
Re: Ultrafast Fibre Plus
If you post a screenshot of the checker results we can tell you whether it will be FTTP or G.Fast.
Longshanks
Message 22 of 66
Happy to do that, but won’t it give away my number, exchange etc?
Message 23 of 66
just delete your number before posting  exchange and cab is not a problem
everyone on the forum apart from mods is a customer just like you with no access to Bt files/records
Longshanks
Message 24 of 66
Here goes.
Message 25 of 66
Interestingly it would appear that both G.fast and FTTP are available to you.
Call the FTTP team
Longshanks
Message 26 of 66
Thanks. Will ring. If the cable from the cabinet had been upgraded to accommodate FTTP, would we have been aware of that? I only ask as Virgin cabled up a few years ago, and I was v conspicuous with digging and laying.
Message 27 of 66
FTTP doesn't involve the cabinet.
Longshanks
Message 28 of 66
Ok. Rephrase that then. Would we have been aware of cabling replacement to the property? (Albeit circumventing the cabinet?)
Message 29 of 66
There would be no cabling replacement to your property until an order is placed. The infrastructure cabling would just be to an splitter node which is either underground or on a pole depending on the distribution method in your locality.
Longshanks
Message 30 of 66
Cheers. Our cabling is underground, so was just curious as to how conspicuous any new cabling would be?
