Longshanks
Message 41 of 66
Re: Ultrafast Fibre Plus
Ok thanks Won’t profess to understand that.
Longshanks
Message 42 of 66
brookheather
Message 43 of 66
By the way ISPreview are now confirming that EE will be selling BT products:
EE’s high street shops will soon fully support BT products and services too in a multi-brand approach.
https://www.ispreview.co.uk/index.php/2019/10/bt-uk-to-launch-halo-unlimited-5g-and-fixed-broadband-...
Longshanks
Message 44 of 66
Re: Ultrafyast Fibre Plus
Thank God for that. Was beginning to think it was a figment of my imagination.  That said, think it’s unfortunate the EE staff only understand Sebo Croat.
Longshanks
Message 45 of 66
Hi
Got am email to say engineer had visited and confirming installation date. Got home and saw this.
Will the fibre replace the copper wire (white insulation) to provide filtered and unfiltered signal? If so, would they use the existing hole in brickwork to feed the new cable? I also understand the ONT will connect to the WAN in the super Hub. Is that right? (At the moment I have Ethernet connecting Openreach modem to WAN on HH5)
Many thanks
Sage
Sage
Message 46 of 66
There is no filtered/unfiltered signal with FTTP. The ONT is the modem. As regards the rest speak to the install engineer.
brookheather
Message 47 of 66
Your copper wire will remain in place to provide voice service as before.  They will install the fibre cable where you want within reason - this could be the same location as the existing copper wire or you could have it installed in a more convenient location assuming the spare fibre cable is long enough.
Message 48 of 66
Will it?  With the intended removal of copper by 2025 (some hope!!) I would have thought the opportunity to move customers to FVA would be taken by any FTTP installs. Perhaps @Starwire might have some info on that?
brookheather
Message 49 of 66
I think FVA is only provided for new builds with FTTP only connections (ATA port provided by ONT).  At some point BT will be moving to VOIP as the solution for voice service and I expect there will be a new HomeHub which will have the ATA port built in - the copper connection will then not be required.  The new 1+0 ONT doesn't even have a voice port which would be required for FVA.
Message 50 of 66
Like this, the Smart Hub 2 with the phone port?
