Longshanks
Message 51 of 66
Re: Ultrafyast Fibre Plus
Thanks for that. I provoked a geyser of techno  babble there didn’t I. I note that copper wire will stay for phone, Thanks.
brookheather
Message 52 of 66
Basically the current plan is by 2025 your voice service will be delivered over FTTP instead of your existing copper cable - when this switch happens you would plug your phone into the phone port on your router instead of your existing copper phone port.  Your copper cable will then become redundant.
Longshanks
Message 53 of 66
Thanks for explaining to the uninitiated.
Message 54 of 66
But it might happen sooner rather than later. 😉
Longshanks
Message 55 of 66
Hi All
V last questions on this installation. Notwithstanding where they site ONT and feed cable through wall:
Will I not need the RG11 cable that currently connects master socket to Openreach modem? (RG11 rendered obsolete by fibre and ONT?)
Assuming master socket will remain to provide separate connection for phone?
Is the “fibre” true fibre in sense of word? I ask, as understood Virgin “fibre” is in fact higher spec copper cable? (Not going to barricades on that)
Thanks for your time, patience and expertise.
Message 56 of 66
@Longshanks wrote:
Hi All
Will I not need the RG11 cable that currently connects master socket to Openreach modem? No, master socket will be purely for telephony after FTTP install (see caveat below)
(RG11 rendered obsolete by fibre and ONT?) Yes
Assuming master socket will remain to provide separate connection for phone? Correct unless your telephony service is moved to fibre voice as discussed earlier.
Is the “fibre” true fibre in sense of word? I ask, as understood Virgin “fibre” is in fact higher spec copper cable? (Not going to barricades on that) Yes, the fibre enters your house and terminates in the ONT (Optical Network Terminator)
Longshanks
Message 57 of 66
Many thanks again. BT final fibre is obviously higher spec than that used by Branson’s lot.
Sage
Sage
Message 58 of 66
They are chalk and cheese in terms of tech. VM is using EURODOCSIS 3.0 at present but has EURODOCIS 3.1 ready to deploy. 3.1 is good for up to 10Gb connection.
Longshanks
Message 59 of 66
Hi
If that is the Virgin cheese, what is the BT chalk, so to speak?
Sage
Sage
Message 60 of 66
I was talking about the technology not the companies.
Perhaps it would have been better for me to say apples and pears.
