Brunton
Message 1 of 9
Ultrafast Fibre from BT - Now available exclusively in your area
Hi,
I have received an email and letter through the post informing me that I can now get broadband with 100Mbps Speed Guarantee. However, when I called up about this BT informed me that it is not available. Would someone be able to assist me in looking into this please?
Thanks in advance
8 REPLIES 8
licquorice
Message 2 of 9
Re: Ultrafast Fibre from BT - Now available exclusively in your area
Put your phone number in the checker and post the results, delete your phone number before posting.
https://www.dslchecker.bt.com/
Brunton
Message 3 of 9
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low        Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date
ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date
Left in JumperObserved SpeedsG.FastVDSLOther Offerings
Availability Date
Premise environmentStatus
VDSL Range A (Clean)8073.3201967AvailableAvailable--
VDSL Range B (Impacted)8070.8201965AvailableAvailable--
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 13--10.5 to 15.5Available----
WBC ADSL 2+ Annex MUp to 13Up to 110.5 to 15.5Available----
ADSL MaxUp to 7--6 to 8Available----
WBC Fixed Rate2----Available----
Max Observed Downstream Speed (Mbps)--66.99
Max Upstream Observed Speed (Mbps)--16.99
Observed Date--2019-09-25
VDSL Multicast------Available----
ADSL Multicast------Available----
Bridge TapN
VRI--
NTEFaceplate--
Last Test Date24-04-2018
imjolly
Message 4 of 9
As you can see from checker results there is no ultrafast  FTTP/G.FAST available to you   the letter is just a circular
DavidM
Moderator
Moderator
Message 5 of 9
Hi @Brunton and welcome to the community.
Sorry for any confusion with this. @imjolly is correct. The results you've posted confirm you can't get the  FTTP/G.FAST  up to 80 meg service. You've more than likely received a circular.
Cheers
David
oakserver
Message 6 of 9
David, I think you mean you can't get the FTTP/G.Fast service but can get the VDSL service up to 80 meg.
DavidM
Moderator
Moderator
Message 7 of 9
I stand corrected @oakserver. Thanks for pointing that out.
Cheers
David
oakserver
Message 8 of 9
Sorry I didn't mean it to sound quite so blunt, it was just a typo 🙂
DavidM
Moderator
Moderator
Message 9 of 9
No offence taken @oakserver. No need to apologise.
Cheers
David
