McDan1el
Newbie
Message 1 of 6
Ultrafast - constant (typically daily) disconnects
Hi,
I moved into a property (new build) back in March 2017 - for 12-18months i used an ASUS router with Inifinity 3 with no issues, don't think i ever had a disconnect.   I've had Ultrafast 1 (145mb) for a little over 6 months now and at least daily the internet just hangs and the HomeHub X reboots.  As soon as it reboots i am instantly connected again, process takes about 3-4minutes.  There is no pattern, nothing hardware wise inthe house has changed for me to think it's interference and sometimes i'm not home when it drops (notifactions on phone for things going offline).  I've rung BT several times who perform line checks, and nothing coming up.
My belief it is the router but the cost of replacement is high for a 3rd party so loathed to spend out ... just in case!  Wondering if anyone else has had issues?
Tried to nab the last d/c from the log - not sure if its right bit and doesnt point to anything obvious:
19:52:25, 04 Feb.
dsl:ADSL Link Down: duration was 0 seconds
19:52:25, 04 Feb.
wl1:Device <60:64:05:9B:87:AB> was disconnected on SSID (Device/WiFi/SSIDs/SSID[WL_PRIV2G])
19:52:25, 04 Feb.
:A device reset was performed (GUI/Button)
19:52:21, 04 Feb.
:HTTP UserAdmin login from 192.168.1.66 successfully
19:52:17, 04 Feb.
:HTTP UserBasic login from 192.168.1.66 successfully
19:52:16, 04 Feb.
19:51:40, 04 Feb.
:The LAN DHCP Server is active
19:51:40, 04 Feb.
:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
19:51:40, 04 Feb.
:The LAN DHCP Server is inactive
19:51:39, 04 Feb.
eth1:IGMP group 239.255.250.250 on interface eth1 ended by 192.168.1.81
19:51:39, 04 Feb.
eth1:IGMP group 239.255.3.22 on interface eth1 ended by 192.168.1.93
19:51:39, 04 Feb.
:VLAN VLAN_DATA disconnected
19:51:39, 04 Feb.
ppp1:Connection to the Internet has been terminated.(Reboot,Reconfiguration,forced termination)
19:51:38, 04 Feb.
ppp1:The DYN ROUTE [81.139.56.100/32 gw ] is deleted
19:51:38, 04 Feb.
ppp1:The DYN ROUTE [81.139.57.100/32 gw ] is deleted
19:51:36, 04 Feb.
ppp1:The WAN DHCPv6 Client Process has successfully been terminated on Vlan 36
19:51:36, 04 Feb.
BR_LAN: Allocated prefix = fdaa:bbcc:ddee::/64 (valid time = 4293967296 / preferred time = 4293967296)
19:51:36, 04 Feb.
19:51:35, 04 Feb.
dsl:VDSL Link Down: duration was 0 seconds
5 REPLIES 5
McDan1el
Newbie
Message 2 of 6
Re: Ultrafast - constant (typically daily) disconnects
Did a filter on logs on PPP - lots of disconnects as you can see 😞
19:51:40, 04 Feb.
19:51:39, 04 Feb.
20:18:55, 03 Feb.
ppp1:PPP: PPP INFO 81.139.57.100,81.139.56.100
20:18:53, 03 Feb.
ppp1:PPP: PPP INFO
20:18:52, 03 Feb.
ppp:PPP: IPCP_NAK
20:18:52, 03 Feb.
ppp:PPP: CHAP_SUCCESS
20:18:52, 03 Feb.
ppp:PPP: CHAP_RESPONSE
20:18:52, 03 Feb.
ppp:PPP: LCP_GOOD_ACK
20:18:52, 03 Feb.
ppp:PPP: LCP_REQUEST
20:18:52, 03 Feb.
:PPPoE error: timeout
20:18:43, 03 Feb.
20:18:38, 03 Feb.
20:17:38, 03 Feb.
20:17:37, 03 Feb.
15:43:59, 03 Feb.
15:43:58, 03 Feb.
ppp1:PPP: PPP INFO
15:43:57, 03 Feb.
ppp:PPP: IPCP_NAK
15:43:57, 03 Feb.
15:43:57, 03 Feb.
15:43:57, 03 Feb.
15:43:57, 03 Feb.
15:43:56, 03 Feb.
15:43:47, 03 Feb.
15:43:42, 03 Feb.
15:42:46, 03 Feb.
15:42:44, 03 Feb.
06:13:26, 03 Feb.
ppp1:PPP: PPP INFO 81.139.56.100,81.139.57.100
06:13:24, 03 Feb.
ppp1:PPP: PPP INFO
06:13:23, 03 Feb.
ppp:PPP: IPCP_NAK
06:13:23, 03 Feb.
06:13:23, 03 Feb.
06:13:23, 03 Feb.
06:13:23, 03 Feb.
06:13:23, 03 Feb.
06:13:06, 03 Feb.
06:12:57, 03 Feb.
06:12:52, 03 Feb.
06:11:55, 03 Feb.
06:11:53, 03 Feb.
22:13:04, 31 Jan.
22:13:03, 31 Jan.
ppp1:PPP: PPP INFO
22:13:01, 31 Jan.
ppp:PPP: IPCP_NAK
22:13:01, 31 Jan.
22:13:01, 31 Jan.
22:13:01, 31 Jan.
22:13:01, 31 Jan.
22:13:01, 31 Jan.
22:12:52, 31 Jan.
22:12:47, 31 Jan.
22:11:53, 31 Jan.
22:11:52, 31 Jan.
Moderator
Moderator
Message 3 of 6
Hi @McDan1el
Welcome to the Community and thanks for posting.
Sorry for the connection problems you're having.  Your best bet would be to contact our FTTP team.  Their number is 0800 5874787.
Keep us posted how things go.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
McDan1el
Newbie
Message 4 of 6
Yea I've rung them a lot, they do a test on line and say no problems detected 😞
Sage
Sage
Message 5 of 6
What's happened to your Asus router?
McDan1el
Newbie
Message 6 of 6
The model I have doesn't support g.fast I can get a newer one but it's around £200 a lot to fork out if it's not a router issue. Might have to bite the bullet
