mike63uk
Message 1 of 2
Ultrafast (g.fast) speed
I had Ultrafast Fibre (G.Fast) installed on the 15th October and the Date Rate has now settled down to 24.06 Mbps / 148.07 Mbps but using speedtest.btwholesale.com my IP Profile is showing as 30 Mbps / 134.83 Mbps. Should there be a 13 Mbps difference in the download speed allowed by the IP Profile?
1 REPLY 1
conrad
Recognised Expert
Message 2 of 2
Re: Ultrafast (g.fast) speed
Yes the IP Profile is always lower then the data rate. These should be the %s for various connections
Normal VDSL 96.79%
When G.INP is active 96.69%
When on 3dB target 92%
ADSL 2+  88.2%
I actually don't know the g.fast % but the difference you are showing is similar to the adsl copper one which may be the most relevant as you are on a copper line , could be wrong though.
