Cefni
Newbie
Message 1 of 6
Unable to order FTTP, but neighbours can
As the title suggests, I am unable to order FTTP even though both my neighbours can.
I have just bought the house, which was previously unoccupied
I assume this is a database issue as there is no phone line in my house at the moment.
here is the openreach result for my house
and here is my next door neighbour (house is 1m away from mine, further away from the pole!)
Can a mod please assist?
Thank you
5 REPLIES 5
Message 2 of 6
Re: Unable to order FTTP, but neighbours can
Have you tried contacting Openreach through their site?
There's a specific form for fibre availability issues. This appears to be a databse issue which they should be able to sort.
Cefni
Newbie
Message 3 of 6
I have used the openreach form to contact then over 5 weeks ago, they replied promising to respond within 7 working days but nothing since then. I hoped someone here may have another route to assist me.
Cefni
Newbie
Message 4 of 6
No-one can help with this?
Message 5 of 6
Have you tried calling the BT FTTP order team on 0800 587 4787
Moderator
Moderator
Message 6 of 6
Hi @Cefni and welcome.
@gg30340 is correct. The only team that can help are the FTTP order guys. Your best bet would be to try the number hes posted.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
