GBNE01
Message 1 of 14
Unable to order Fibre - neighbours appear to be able.. NEW BUILD
Hi there!
I've done some scanning through forums, and this appears to be a reasonably common sort of issue. I'm just about to move into a new build property, the area is supplied by cabinet, and is specced up for FTTC.
When I try to order I'm told that only ADSL is available, but if I try a property across the road (which hasn't even been populated yet) they come up as 'superfast broadband is available' on the openreach checker.
It feels like an administrative error, but I'm not discounting the fact that maybe the cabinet is full?
Does anyone have a good means of getting this checked out? I've been promised about 5 times (verbally....) by sales reps that fibre was available, and I don't want to go back to '10 years ago' style ADSL.
any help will be greatly welcomed!
13 REPLIES 13
imjolly
Message 2 of 14
Re: Unable to order Fibre - neighbours appear to be able.. NEW BUILD
as you don't have a phone number try new address http://dslchecker.bt.com/adsl/adslchecker.welcome
GBNE01
Message 3 of 14
Thanks for that!
When I use the address checker (and use my house number and postcode) I get this result. Can someone interpret what this means? Should this indicate if the cabinet is full?
imjolly
Message 4 of 14
there should be an exchange and cab shown at top of chart
from what you posted there is no fibre available to you at present that may change when you get in and can get phone line
the FTTP on demand is for business
licquorice
Message 5 of 14
Is the cabinet number the same for both your property and the property that has FTTC?
If the cabinet was full the checker would still show projected FTTC speeds but annotated with 'Waiting List'.
GBNE01
Message 6 of 14
Again, thanks for the quick responses, much appreciated.
This is what I get when I check across the road..
imjolly
Message 7 of 14
please delete the address   you need to leave the chart if possible  exchange is Gorebridge cab 2
is that the same cabinet you see when you run the checker?
GBNE01
Message 8 of 14
Yes indeed - looks the same
imjolly
Message 9 of 14
the adsl stats on your checker results are not the same as the neighbour's results suggesting you are further from the exchange but could still be on same cabinet
GBNE01
Message 10 of 14
As far as I can see, there's only one cabinet in the whole estate - could this just be a database issue then? i.e. I get a phone line installed and it all springs into life?
