waynehibbs
Message 11 of 14
Re: Unable to upgrade my fttp infinity boardband and fibre phone that was installed last month.
ok thank you for your help, sorry fo the upper case.
wayne
StuartH
Moderator
Moderator
Message 12 of 14
Hi @waynehibbs
Please post back and let us know how you get on.
Stuart
waynehibbs
Message 13 of 14
hi i called the number you gave me and spoke to them it noiw all sorted.
the problom is that standed broads us the phone number to check the accoiunt.
but with finre is uses the account number to check for service, as my ohine was moved to fibre online service can not help
thanks for your help
StuartH
Moderator
Moderator
Message 14 of 14
Hi @waynehibbs
Glad to hear that this is sorted it for you, did you manage to get the issue with the usage allowance resolved as that part is unusual for a fttp product?
Stuart
