Infinite_User
Message 1 of 37
Unlimited BT Infinity 2 slower than normal broadband
Hello,
My BT Infinity 2 was installed yesterday afternoon and my download speeds have been between 5 - 15 Mbps since.I spent over an hour on live chat last night but could not get the issue resolved and was told I would receive a call back on Sunday night as the line may need time to stabilise.
I am not optimistic that my Broadband speeds will miraculously recover in this period as the speedtests I have conducted tonight are showing similar results and would like to ask for help/advice on how best to tackle this issue in the meantime.
Thank you.
36 REPLIES 36
Distinguished Guru
Message 2 of 37
Re: Unlimited BT Infinity 2 slower than normal broadband
Can you post your helpdesk data from the HH5 please? These are in Troubleshooting/Helpdesk on the web interface at http://192.168.1.254 or http://bthomehub.home
Please miss out any data you don't want to post
If not, I'll try again 🙂
Infinite_User
Message 3 of 37
Hello Ray,
Distinguished Guru
Message 4 of 37
Ok so you're getting 66Mbps downstream. Are your problems with wireless or are you using wired ethernet?
Infinite_User
Message 5 of 37
Currently using wired ethernet just to my PC atm.
Distinguished Guru
Message 6 of 37
Was Infinity engineer-installed or self-installed?
Infinite_User
Message 7 of 37
Engineer installed (sub contracted I think)
Distinguished Guru
Message 8 of 37
Did he fit a new master socket like this?
Infinity Master Socket
Infinite_User
Message 9 of 37
Yes that's the one mine has MK3 on the top right faceplate.
Distinguished Guru
Message 10 of 37
Can you post the estimate for your line given by www.dslchecker.bt.com please?
Please don't post your phone number as this site is indexed by Google.
