Moderator
Moderator
Message 11 of 15
Re: Unreliable broadband
Hi @Alexandersim2  thanks for the update and as it was intermittent monitor it over the weekend and see how things go.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
Moderator
Moderator
Message 12 of 15
Hi @Alexandersim2  How has the connection performed over the last few days? If everything is working ok are you happy for me to close the case now. Post back and let me know.
cheers
John
Kudos”Kudos”
Message 13 of 15
@Alexandersim2   I would keep a check on your bill for the next couple of months as all the things you mention the engineer did to fix the problem were on your side of the test socket and normally deemed to be a customer problem and chargeable - £85 for engineer visit
Moderator
Moderator
Message 14 of 15
Hi @Alexandersim2  thanks for updating me via PM. Sorry you are still experiencing drops. I've checked your connection since the engineer visit and the speed has gone back up and there have been no drops. Do you have any wired devices that have dropped the connection or have the lights on the hub changed when the drops happened. I know you were away for a few days so post back and let me know when you get a chance to check.
Cheers
John
Kudos”Kudos”
Moderator
Moderator
Message 15 of 15
Hi @Alexandersim2  thanks for getting back to my PM and I'm very happy to hear your connection is very stable now since the engineer visit.
Cheers
John
Kudos”Kudos”
