Message 11 of 17
Re: Unreliable speed again, il, post some data here to build a history.
Ok David, I will try later.
18/5/1918/5/19
we we have been contacted by BT, and a new hub is being sent to us. We’ll see what the quiet line test does, and see what the new hub brings with it.
Moderator
Moderator
Message 12 of 17
Thanks for getting back to me @stoatsngroats .
Hopefully the new hub will sort things out but keep me in the loop, I'm sure we'll be able to get this resolved for you.
Cheers
David
Message 13 of 17
Thanks David, I’ll keep you posted on here, once the new hub arrives.
Message 14 of 17
Today’s speed....Today’s speed....
Message 15 of 17
Re: Unreliable speed again, I’ll post some data here to build a history.
This before a reset....This before a reset....This after a reset...This after a reset...
So, can someone tell me if there’s any issue with my Hub? I’m hoping there’ll be a new one in the post tomorrow, and that my broadband will become a decent speed. I get that there are connection to the cabinet, and connection to the exchange problems possible, but how can there be such an improvement followinga reset, if the problem is anything other than my hub?
Message 16 of 17
New Hub connected, and looking at 65Mbps currently, so fingers crossed our issues are resolved. I will continue to add images here periodically to see how this progresses.
Moderator
Moderator
Message 17 of 17
Hi @stoatsngroats  thanks for the update with the new hub and do keep the thread updated.
Cheers
John
