imjolly
Message 11 of 12
Re: Unstable Connection - several months, several calls, an engineer visit and worse than ever
that's more what I would expect with higher than normal 6db noise margin causing lower connection speed  however your attainable has reduced as well and you are now below estimate
the test socket is behind bottom half of the master socket and you normally get a filter when you receive the hub or probably still have one from your adsl days
test socket shown by black arrow
PaulV000
Message 12 of 12
Hi
Thanks for your help.  I took those last stats when the connection was having a wobbly period before.  Next time it's having a wobble and I'm online I'll get two lots of fresh stats, one from the test socket.  I always use a filter anyway fyi.  Also fyi this is a replacement socket which the engineer put in place on his visit a few weeks ago (just to rebrand us to Openreach I think I gathered).
Paul
