OriginalGuinness
Message 1 of 4
Up-Grade
Hi Guys,
I've just up-graded to the full fibra 900 with halo 3 from Halo 2 (150) this was on the 20st of Dec. I'm still only getting my old speed! The e-mail told me my new update would start on the 21st..I know its only a couple of day. How long does it take to swop over. I have FTD, so I though it was just a matter of flicking a switch.. Thoughts.
Many thanks,
AB
3 REPLIES 3
pippincp
Message 2 of 4
Re: Up-Grade
How are you testing your speed? Wired or wireless?
What is FTD?
OriginalGuinness
Message 3 of 4
Re: Up-Grade
Tried both  Wired & wireless.  Fibra to Door.
pippincp
Message 4 of 4
Re: Up-Grade
FTD doesn't exist except as a medical term (FTD is the most common form of dementia for people under age 60. It represents a group of brain disorders caused by degeneration of the frontal and/or temporal ...}.
Either FTTP or FTTH.
Give the FTTP tem a ring, they should be able to chech if the upgrade has gone through or if there is any other problem. 0800 587 4787
