Message 11 of 15
Re: Upgrade from Infinity 1 to Superfast Fibre Plus = Same Speed
You are basically getting the same speed as you had before but according to checker your line estimated speed is 80/60mb so would expect to get about the 55mb connection speed but even your attainable is not in your estimated range so I would phone customer services and get engineer visit especially as you are using test socket
andyjeff66
Message 12 of 15
I don't believe BT want to speak to me. I've tried over the phone and had the call centre close on me. I tried over chat and had the agent leave the chat. I just tried to book an engineer through the online troubleshooter only to have that fail while it was confirming the appointment.
I shall try again in the morning.
Message 13 of 15
You should be complaining that your connection speed is well below your handback speed even when using the test socket so you need a broadband engineer visit   Post back let us know how you get on
andyjeff66
Message 14 of 15
Engineed booked for Thursday morning with a follow up call promised for the afternoon. I'll let you know how it goes.
andyjeff66
Message 15 of 15
So we have signs of improvement along with a new 5c Master Socket. Engineer has just been and explained that the cable I was on seemed to be quite an old one that was getting a lot of crosstalk on the line. So he's switched me onto a newer cable that he says has 0 crosstalk on it. There's been an improvement but it's still below BT's minimum guarentee but I'll give the line some time to settle.
