Message 11 of 14
Re: Upgrade from "Broadband Unlimited" to "Fibre 1"
Have  you  connected modem to the broadband socket on master socket then conenct to wan port on billion. You need to set username to bthomehub@btbroadband.com and password bt and see if it connects
Message 12 of 14
The ECI modem will be completely locked and not configurable, just plug and play. TR 069 is a protocol for BT to access and update firmware on the modem.
Message 13 of 14
Thanks I will do that.
Message 14 of 14
Thanks!
... which should work fine hopefully?
... which is no longer necessary/used for this old device?
