Jackie1970
Message 1 of 8
Upgrade to Infinity Problem
Hi all,
Just before Christmas I put in an order to upgrade our connection from ADSL to Infinity.
I think something has gone awry as we are still waiting and I wonder if someone here may look for me as the support lines are closed by the time I get home from work
Thanks in advance
Jackie
7 REPLIES 7
Message 2 of 8
Re: Upgrade to Infinity Problem
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
we can then advise you further
Message 3 of 8
if you check your order is it pending or been cancelled?
if cancelled then phone the options team who are uk based and they will help you 0800800030
Jackie1970
Message 4 of 8
Jackie1970
Message 5 of 8
Hope this is what you meant, it is a bit of confusion !!
Jackie1970
Message 6 of 8
Message 7 of 8
So looks like order failed   was there anything in notes to dslchecker about cabinet full or no capacity at present?
If nothing in notes then use the potions team who will help  0800800030
Jackie1970
Message 8 of 8
Theres nothing like that so ill give them a ring, thanks
