caithnesslad
Message 11 of 19
Re: Upgrade to Infinity slower than old broadband connection
Thanks.
Could this sort itself out in the '10 day settling period'?
that's the only answer I got from the live chat/help.
Thanks again
Message 12 of 19
Are you sure that you are as close to the cabinet as you think?
If you are,then as others have said, you need the problem investigated.
caithnesslad
Message 13 of 19
Just did the quiet line test - all clear.
I'd estimate 250-300m to the cabinet but when the engineer fitted the master socket a couple of weeks ago he said 150m was what his test gear showed.
Moderator
Moderator
Message 14 of 19
Hi @caithnesslad
I can get this investigated further for you. Send me in your details using the contact the mods link in my profile. The contact form will ask you for all the details we need to investigate this fully.
Stuart
Community ModeratorStuartH
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Colin_London
Recognised Expert
Message 15 of 19
Yes - you have a problem. Looks like the profile still thinks you are on ADSL. It needs a profile reset.
Message 16 of 19
as I said yoiu need mod help so take up mod offer and complete the form
caithnesslad
Message 17 of 19
Thanks all,
I've contacted the mods through StuartH as requested.
Fingers crossed this will get it sorted.
Moderator
Moderator
Message 18 of 19
Hi @caithnesslad,
Thank you for taking my call today. I'm really happy to hear the engineer was able to identify and fix the fault.
Please keep an eye on your connection over the next few days. If you notice any issues, please get back to me.
PaddyB
Community ModeratorPaddyB
Kudos”
caithnesslad
Message 19 of 19
Problem solved - an issue in the exchange sorted by engineer.
Thanks to all for your help.
