mikebren12
Message 11 of 23
Re: Upgraded infinity 2. No change
After unscrewing the front and putting straight into the socket
cheers
mike
Message 12 of 23
You need an engineer visit.
mikebren12
Message 13 of 23
Cheers Webby,
based on what??
if you could elaborate that would be great..
Mike
Distinguished Guru
Distinguished Guru
Message 14 of 23
Your max attainable rate is less than indicated by the checker.
mikebren12
Message 15 of 23
Got to be honest that means nothing to me 😂
Message 16 of 23
Your speed is considerably lower than Openreach estimate ot should be.
mikebren12
Message 17 of 23
Cheers, engineers coming on the 18th
Mike
Moderator
Moderator
Message 18 of 23
@mikebren12 Post back and let us know how the visit goes.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
mikebren12
Message 19 of 23
Will do
mikebren12
Message 20 of 23
Ok, so engineer came out yesterday.. said there was errors on the line, changed the master socket. Then went to the box approx 450 mars away and that was showing I was indeed on 80/20 line. So then went to the unit outside my property which was showing for some reason I could only receive up to 38mb/sec, played around with that and now
i have 50 down and 15 up...
it it seems you just have to keep pushing with Bt, hope this helps ...
mike
