ZomBieZA
Message 21 of 38
Re: Upgraded to BT Fibre, order is still open and nothing has changed.
Here we go
licquorice
Message 22 of 38
No reason why you shouldn't be able to order according to that. Place an order and see what happens.
JohnC2
Moderator
Moderator
Message 23 of 38
Hi @ZomBieZA  I agree with @licquorice  there doesn't appear to be any reason why you can't order fibre. Place your order and keep us updated on the progress of the order.
Cheers
John
imjolly
Message 24 of 38
Try options team 0800800030
ZomBieZA
Message 25 of 38
Thank you, I will be doing this as when I go to my account it says I should. Should I do it now or wait for monday? I dont want to sit without internet over the weekend.
licquorice
Message 26 of 38
Nobody will be doing anything for several days/weeks, so place the order at your convenience.
The changeover should only take minutes in any case.
ZomBieZA
Message 27 of 38
Hi, today is the day that it should be upgraded. Internet has gone off and on a few times already, though now its been off for almost an hour. BT Hub is just steady orange.
My BT package shows it's been upgraded already.
This is the same thing that happened last time I tried upgrading.
Keith_Beddoe
Message 28 of 38
Could be an issue with cable routing records, as its happened again.
Is your phone line working?
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
ZomBieZA
Message 29 of 38
Thank you, yes my telephone is working.
Keith_Beddoe
Message 30 of 38
And the new BT Smart hub is connected in the same place as it was when you were on ADSL?
