jaydog69
Message 1 of 9
Upgraded to Infinity 2 - No Speed Difference?
Last year, I was with BT on Infinity 1 and I had the free speed boost. This meant I was getting around 75mbps pretty much all the time.
I then made the mistake of going to Sky in December... I came back to BT in Feb this year on Infinity 1, which I solidly get 52mbps downloads.
Yesterday, I decided to upgrade to Infinity 2. Today the order is complete, but only my upload speed has really changed - it's doubled. My download speed is a little faster at about 54mbps.
Why is it only 2mbps faster when last year I could get 75mbps? I contacted BT and they said I should wait for the line to settle, which I don't believe to be true. The upload speed doubled straight away, but not the download speed.
Any ideas? Here's my line stats, and I have already tried a restart of the hub with no change -
 Downstream sync speed:
58.75 Mbps
 Upstream sync speed:
20.00 Mbps
Data rate:
20.00 Mbps / 58.75 Mbps
Maximum data rate:
24110 / 60493
Noise margin:
15.3 dB / 6.2 dB
Line attenuation:
14.7 dB
Signal attenuation:
8 REPLIES 8
jaydog69
Message 2 of 9
Re: Upgraded to Infinity 2 - No Speed Difference?
Bump
Message 3 of 9
there is no need to 'bump' as someone will answer
you have been upgraded to infinity 2 but from your stats your max attainable is 60mb so a conenction speed of 58.75mb is correct
have you tried connecting to test socket with a filter even it you have a filtered master to see if that improves your conenction
enter your phone number and post results  remember delete number http://dslchecker.bt.com/adsl/adslchecker.welcome
jaydog69
Message 4 of 9
In that case, why am I not getting the 75mbps I used to get before I left to go to Sky?
My stats are -
Telephone Number 01xxxxxxxxx on Exchange SAINT FAITH is served by Cabinet 11
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low        Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date   ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date Left in JumperOther Offerings     Availability Date   Premise environmentStatus
VDSL Range A (Clean)8060201953.3AvailableAvailable--
VDSL Range B (Impacted)77.652.72016.439.8AvailableAvailable--
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 3--2 to 4Available----
ADSL MaxUp to 3--2 to 4Available----
WBC Fixed Rate1----Available----
VDSL Multicast------Available----
ADSL Multicast------Available----
Bridge TapU
VRIN
NTEFaceplateN
Last Test Date03-04-2018
Message 5 of 9
Be you tried the test socket with a filter?
what speed did you get before you left sky
jaydog69
Message 6 of 9
I was getting 68mbps with Sky.
I haven't tried the test socket no as I've not had issues at all until going onto infinity 2 with BT.
Message 7 of 9
Maybe you need to try the test socket as from your stats the attainable is 60mb and your noise margin is about normal 6db suggesting no more scope for more speed with existing setup
jaydog69
Message 8 of 9
I don't want to keep rebooting my router to be honest.
November 2017, I was on Infinity 1 with the speed boost and getting a constant 75mbps so I'm confident it's not the wiring.
Message 9 of 9
Then I don't think your router will reboot at a faster speed
