GaryM30
Message 1 of 6
Upload Speed Half what it was..
Hi, Sorry to ask the same question I see posted on here very frequently.
My download speed is exactly where is should be, but for a month or so I have watched my upload speed steadily drop from 8/9mb to 5mb. It has run at the higher speeds for well over a year.
BT Hub 6 states that it is at 6mb, but clearly not uploading at that speed.
Whilst I appreciate it is not in the realms of being unusable,
I just wondered if anyone would take a look at my stats and offer any advoce.
Many Thanks,
Gary.
1. Best Effort Test: -provides background information.
 Download Speed
 44.75 Mbps
0 Mbps46.11 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 44.75 Mbps
 For your connection, the acceptable range of speedsis 27.5 Mbps-46.11 Mbps .
 Additional Information:
 IP Profile for your line is - 46.11 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 5.08 Mbps
0 Mbps10 Mbps
Upload speed achieved during the test was - 5.08Mbps
 Upstream Rate IP profile on your line is - 10 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Please visit the FAQ if you are unable to understand the test results.
This is a quick overview of your BT Smart Hub's status.
Product name:
BT Hub 6A
Serial number:
+084317+NQ62380143
Firmware version:
SG4B1000B540
Firmware updated:
23-May-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
1 Days, 22 Hours 28 Minutes 5 Seconds
Data rate:
6.02 Mbps / 49.87 Mbps
Maximum data rate:
6002 / 51797
Noise margin:
5.9 dB / 3.4 dB
Line attenuation:
20.9 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
5 REPLIES 5
Message 2 of 6
Re: Upload Speed Half what it was..
from the stats you have posted you have an up speed of 6mb and upload speed of 5mb which looks what you would expect from your information
Distinguished Guru
Distinguished Guru
Message 3 of 6
I think you mean download of 50Mb @imjolly Smiley Very Happy
Message 4 of 6
@pippincp
no I intended 'upload' and have changed it Smiley Happy
thanks
Distinguished Guru
Distinguished Guru
Message 5 of 6
Smiley Very Happy
GaryM30
Message 6 of 6
Thank you for your input, much appreciated.
Didn't really address how or why I have lost nearly 50% of my upload capability.
No worries, Hopefully it will sort itself out.
