jmparpet
Message 1 of 3
Upload Speed issue (BT Infinity 2)
Hi,
First post, so go easy on me.
I am experiencing a huge drop in upload speed since a few months ago.
My modem (not a BT modem) used to synchronise at around 20Mb/s, which was the advertised rate, or even better. However, since a few months ago it only synchronises at 4.6Mb/s (see attached).
Fritz
I have called BT customer service who told me that they cannot guarantee upload speeds.
I find it outrageous that they would not even investigate the line, since it used to connect at full speed before.
Is there anything I can do?
Cheers.
JM
Tags (1)
2 REPLIES 2
Message 2 of 3
Re: Upload Speed issue (BT Infinity 2)
this looks like a fritzbox problem  https://community.bt.com/t5/BT-Infinity-Speed-Connection/BT-Infinity-2-FritzBox-7390-slow-syncing-up...
jmparpet
Message 3 of 3
It looks like it indeed! Thanks a lot, that's very helpful!
