Disturbedmaster
Message 1 of 6
Upload speed Question????
is it possible to increase upload speed??? I, currently on BT Infinity 1
5 REPLIES 5
Distinguished Guru
Distinguished Guru
Message 2 of 6
Re: Upload speed Question????
The simple answer is no as no ISP in the UK supports upload speeds. All connections are sold on download speeds. That said if  an upload of to lower a speed makes your download unsusable then something would have to be done.
What are your current up/down speeds?
Disturbedmaster
Message 3 of 6
17.5 Down and 2.3 up
Message 4 of 6
That download speed is  very low, so that will affect upload as well, as the two are related.
In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
Disturbedmaster
Message 5 of 6
Distinguished Guru
Distinguished Guru
Message 6 of 6
Althogh you upload speed is low so is your download, it is however within the rates given by the checker.
I can't see anything being done about it. You must be a fair distance from the cabinet.
