Message 1 of 2
Upload speed capped at 20Mbps Full fibre 900
Hi
Had Full Fibre install today and reading in the forums there are some issues with upload speeds being capped at 20 and I'm having the same issue.
Most have needed help from a MOD to get this sorted.
Please MOD ta 🙂
1 REPLY 1
Message 2 of 2
Re: Upload speed capped at 20Mbps Full fibre 900
the mods no longer have account access like the ones you read so you need to phone CS 03301234150 and they should be able to help you.  it may correct itself if only installed today
