Message 1 of 13
Upload speed drop.
Hi,
About 2 months ago my usual 14mb/1.4mb fibre broadband suddenly changed to erratic 11mb/0.3mb.
My usual connection was never fast but it was stable.
So I've tried BT helpline about 5 times since this has happened and not surprisingly got nowhere because the 11mb I get is within BTs accepted tolerance for download.
So I've tried a few things myself now and if I repeatedly factory reset my router I can sometimes get a flukey better connection of 14mb/0.6mb but this is still less than half the upload I used to get.
So not sure how to progress now, aside from cancelling BT as soon as my time is up.
Read a few similar posts to this who all had engineers fix there problems but not sure how to convince BT there is a problem.
All test done with a single device wired straight to HH6.
I suppose a non BT router might be worth a try to see if it's upstream connection speed is any higher.
Any answers much appreciated.
Tags (2)
12 REPLIES 12
Message 2 of 13
Re: Upload speed drop.
Post stats from hh6. Advanced settings then technical log information
run btspeedtester and when first test completes run diagnostic test and post results must be done with wired connection and preferably with IE/edge. http://www.speedtest.btwholesale.com/
Try quiet line test. Dial 17070 option 2 should be quiet and best with corded phone
Message 3 of 13
This is a list of your BT Smart Hub settings and current statistics.
Product name:
BT Hub 6A
Serial number:
+084316+NQ74319738
Firmware version:
SG4B1000B540
Firmware updated:
23-Jun-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
2 Days, 1 Hours 47 Minutes 21 Seconds
Data rate:
598 Kbps / 15.08 Mbps
Maximum data rate:
636 / 19037
Noise margin:
7.3 dB / 7.2 dB
Line attenuation:
30.2 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
5600 MB Uploaded / 45665 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-PTW7
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BTHub6-PTW7
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
A0:39:EE:5A:E7:F5
Software variant:
Boot loader:
9.2.0
Message 4 of 13
1. Best Effort Test: -provides background information.
 Download Speed
 10.78 Mbps
0 Mbps14.6 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 10.78 Mbps
 For your connection, the acceptable range of speedsis 10.22 Mbps-14.6 Mbps .
 Additional Information:
 IP Profile for your line is - 14.6 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 0.46 Mbps
0 Mbps10 Mbps
Upload speed achieved during the test was - 0.46Mbps
 Upstream Rate IP profile on your line is - 10 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Message 5 of 13
Sorry copy and paste didn't work out quite right.
Message 6 of 13
Ok, so watching my noise margin is now
 Noise margin:
7.5 dB / 7.1 dB
Is that acceptable?
Message 7 of 13
Normal noise margin is about 6db. Your down margin is slightly high and allows your connection speed to move closer to attainable speed. Your up speed is low but need you to enter phone number and post results remember delete number https://www.btwholesale.com/includes/adsl/main.html
Message 8 of 13
Message 9 of 13
So the downstream handback threshhold is 12.5mb and my test indicates that i am below that, so does that mean I have a fault?
Message 10 of 13
From your router stats you connection speed is 15mb so you are above the threshold value. All speed quoted by BT are connection speeds not download speeds
