Message 1 of 4
Upload speed issues
Hi everyone,
I have fibre broadband and get download speeds of around 27mb but low upload speeds of around 2mb.
My estimated upload speed is between 5 and 7mb but at 2mb it's pretty much unusable. If we try to upload photos to Flikr of the kids the internet stops, so we cannot upload or download. An engineer came out about a month ago and for about a week the speeds increased, 35mb download and 5.5mb upload. But now, back to 27mb and 2mb.
BT have said that there is no point lodging a complaint as it will be taken off the system because they don't have to do anything with upload speeds. I understand that they can't guarantee upload speeds, but surely they should guarantee it actually works, or what's the point in having it? Am I being unreasonable thinking that 2mb upload speed for fibre is poor?
Any help or ideas would be appreciated in terms of what I can do next please.
Many thanks.
3 REPLIES 3
Message 2 of 4
Re: Upload speed issues
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
run btspeedtester with ethernet connection and post results   https://www.speedtest.btwholesale.com/
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 3 of 4
Hi, thank you for replying. This is the technical log info.
Product code:Smart Hub 2
Serial number:+091298+1945034842
Firmware version:v0.17.01.12301-BT
Firmware updated:Fri May 15 11:39:03 2020
Board version:R01
GUI version:1.56 15_02_2019
DSL uptime:0 days,13 Hours49 Mins01 Secs
Data rate:2.696 Mbps / 31.829 Mbps
Maximum data rate:5.405 Mbps / 41.954 Mbps
Noise margin:10.2 / 6.4
Line attenuation:7.0 / 23.4
Signal attenuation:5.2 / 27.8
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:1.5 GB Uploaded / 18.8 GB Downloaded
Broadband username:bthomehub@btbroadband.com
BT Wi-fi:Activated
2.4 GHz wireless network name:BT-8JAFNW
2.4 GHz wireless channel:Smart (Channel1)
5 GHz wireless network name:BT-8JAFNW
5 GHz wireless channel:Smart (Channel44)
Wireless security:WPA2 (Recommended)
Wireless mode:Mode 1
Firewall:On
MAC address:0C:8E:29:43:7C:CF
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017)
Quiet line test seems fine.
BT speed tester results: ping 101ms, download 17.57mb, upload 2.58mb
Thank you.
Message 4 of 4
Any thoughts anyone please?
