UrbanGrunt
Expert
Message 1 of 13
Upload speed
High upload for ip profile 29.03? http://speedtest.net/result/2473797008.png
Only upload and ping seem to want to improve on my connection :S
12 REPLIES 12
Sage
Sage
Message 2 of 13
Re: Upload speed
Would you like to expand on your issue as the result you posted looks OK?
UrbanGrunt
Expert
Message 3 of 13
Re: Upload speed
Just the fact that DLM won't increase my download back to the original speed (60meg) but it seems to have reduced ping and increased the upload back to normal.
Guru
Message 4 of 13
Re: Upload speed
Doesn't look ok, the ratio is way off...
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
Guru
Message 5 of 13
Re: Upload speed
How long has DLM had since the problem was fixed and the upload/ping improved?  Have you disconnected/reconnected the router (not modem) recently to ensure the IP profile matches the sync speed?
johnalan
Message 6 of 13
Re: Upload speed
Just wondering what you would consider a normal ratio?
UrbanGrunt
Expert
Message 7 of 13
Re: Upload speed
Yes I have disconnected/reconnected my router (I do this every 3 days or so) and I'm able to see my line stats from my ECI modem.
Openreach have been due to visit twice but wasn't able to come due to bad weather and the other just didn't turn up.
As for upload/ping being great this is always short lived and things will eventually be back to "normal" to match my download speed. For example 11 upload and 25ms ping
I'm currently in contact with the mods and will hopefully get a new date for openreach to come and look into things
UrbanGrunt
Expert
Message 8 of 13
Re: Upload speed
Personally for 29meg ip profile I'd expect the upload to be no more than 11-13 but in my case I'm basically getting "max" upload speed on a 29meg ip profile
Sage
Sage
Message 9 of 13
Re: Upload speed
Speedtest.net does not give you your IP Profile. Where did you get your profile from?
UrbanGrunt
Expert
Message 10 of 13
Re: Upload speed
BT speedtester
