cb123456
Message 1 of 3
Uploads cause connection to drop repeatedly
My broadband connection repeatedly drops when there are uploads in progress.
The problem seems very similar to these threads:
https://community.bt.com/t5/BT-Infinity-Speed-Connection/Uploading-causes-drop/td-p/1763993
https://community.bt.com/t5/BT-Infinity-Speed-Connection/Uploading-causing-connection-drop/td-p/1766...
https://community.bt.com/t5/BT-Infinity-Speed-Connection/Uploading-causes-drop-2/td-p/1766833
Hub version is the same as the threads above: BT Home Hub 5 (Type A) | Software version 4.7.5.1.83.8.236.1.2
Unfortunately all those have been solved without the solution being publicly available. Does anyone know the actual solution?
Log extract below.
Thanks in advance for any help!
20:23:32, 18 Sep.(38319.050000) WAN operating mode is VDSL
20:23:32, 18 Sep.(38319.050000) Last WAN operating mode was VDSL
20:23:29, 18 Sep.(38315.900000) PPP IPCP Receive Configuration ACK
20:23:29, 18 Sep.(38315.890000) PPP IPCP Send Configuration Request
20:23:29, 18 Sep.(38315.880000) PPP IPCP Receive Configuration NAK
20:23:29, 18 Sep.(38315.880000) PPP IPCP Send Configuration ACK
20:23:29, 18 Sep.(38315.880000) PPP IPCP Receive Configuration Request
20:23:29, 18 Sep.(38315.870000) PPP IPCP Send Configuration ACK
20:23:29, 18 Sep.(38315.870000) PPP IPCP Receive Configuration Request
20:23:28, 18 Sep.(38315.440000) PPP IPCP Send Configuration Request
20:23:26, 18 Sep.(38312.460000) PPPoE is up -​ Down Rate=29963Kbps, Up Rate=6096Kbps; SNR Margin Down=8.3dB, Up=6.1dB
20:23:26, 18 Sep.(38312.450000) CHAP authentication successful
20:23:25, 18 Sep.(38312.400000) CHAP Receive Challenge
20:23:25, 18 Sep.(38312.400000) Starting CHAP authentication with peer
20:23:25, 18 Sep.(38312.400000) PPP LCP Receive Configuration ACK
20:23:25, 18 Sep.(38312.390000) PPP LCP Send Configuration Request
20:23:25, 18 Sep.(38312.390000) PPP LCP Receive Configuration Reject
20:23:25, 18 Sep.(38312.390000) PPP LCP Send Configuration ACK
20:23:25, 18 Sep.(38312.390000) PPP LCP Receive Configuration Request
20:22:52, 18 Sep.(38279.260000) PPPoE is down after 4 minutes uptime [Disconnected]
20:22:48, 18 Sep.(38275.210000) PPP LCP Send Termination Request [PPPoE PADT received]
20:18:44, 18 Sep.(38030.920000) WAN operating mode is VDSL
20:18:44, 18 Sep.(38030.920000) Last WAN operating mode was VDSL
20:18:41, 18 Sep.(38027.760000) PPP IPCP Receive Configuration ACK
20:18:41, 18 Sep.(38027.760000) PPP IPCP Send Configuration Request
20:18:41, 18 Sep.(38027.750000) PPP IPCP Receive Configuration NAK
20:18:41, 18 Sep.(38027.750000) PPP IPCP Send Configuration ACK
20:18:41, 18 Sep.(38027.750000) PPP IPCP Receive Configuration Request
20:18:41, 18 Sep.(38027.730000) PPP IPCP Send Configuration Request
20:18:38, 18 Sep.(38024.720000) PPPoE is up -​ Down Rate=29963Kbps, Up Rate=6096Kbps; SNR Margin Down=8.3dB, Up=6.1dB
20:18:38, 18 Sep.(38024.710000) CHAP authentication successful
20:18:38, 18 Sep.(38024.650000) CHAP Receive Challenge
20:18:38, 18 Sep.(38024.650000) Starting CHAP authentication with peer
20:18:38, 18 Sep.(38024.650000) PPP LCP Receive Configuration ACK
20:18:38, 18 Sep.(38024.640000) PPP LCP Send Configuration Request
20:18:38, 18 Sep.(38024.640000) PPP LCP Receive Configuration Reject
20:18:38, 18 Sep.(38024.630000) PPP LCP Send Configuration ACK
20:18:38, 18 Sep.(38024.630000) PPP LCP Receive Configuration Request
20:18:38, 18 Sep.(38024.630000) PPP LCP Send Configuration Request
20:18:04, 18 Sep.(37991.430000) PPPoE is down after 3 minutes uptime [Disconnected]
20:18:01, 18 Sep.(37987.500000) PPP LCP Send Termination Request [PPPoE PADT received]
2 REPLIES 2
Sage
Sage
Message 2 of 3
Re: Uploads cause connection to drop repeatedly
As you have note this has happened a few times previously and only the mods seem to have been able to resolve it.
To that end I'll notify a mod for you.
Community Manager
Community Manager
Message 3 of 3
Hi @cb123456
Welcome to the community, I'm sorry you're having this problem.
Can you send us your details and we'll take a closer look at this? You can get our contact link by clicking on my username.
