Message 1 of 12
Using my own router
What details do I need to enter to be able to use my own router ?
11 REPLIES 11
Message 2 of 12
Re: Using my own router
if you use smart setup in own router selecting BT broadband then
username   [email protected]
password can be anything but many just use BT
Message 3 of 12
Connection type is PPPoE
Message 4 of 12
@asd230
What type of package are you on as the setup might vary depending?
Anonymous
Not applicable
Message 5 of 12
For simplicity and efficiency if you're on a BT 300mbps or above just spend £20 on a EE router from e Bay
Literally plug and play.
Personally think 3rd party router's look hideous,  akin to a dead spider.
Message 6 of 12
Give me a 3rd party router - preferably Asus - any time.
Message 7 of 12
Agreed, I’ll take a good third party router every time over an ISP offering.
Anonymous
Not applicable
Message 8 of 12
Why?
Emperors new clothes?
Message 9 of 12
@Anonymous simple. a 3rd party router give you much more control that ISP equipment doesn't offer.
Anonymous
Not applicable
Message 10 of 12
You have to admit though they are aesthetically horrific
