Message 1 of 2
Using own router with FTTP
Just looking for some advice setting up my TP-Link Archer VR600 v2.1 with FTTP Full fibre 100. Looking online this appears to be possible, the box/website also states compatibility with fibre connections but I’ve not been having much luck.
I’m connecting the WAN port on the TP-Link to ONT via a cat6a cable. Going via the quick set up I select “Other” Connection, PPPoE, [email protected] (password: BT), also tried bt and no password. The device fails to connect to the internet.
Hoping for some advice/being advised on what I’m doing wrong.
1 REPLY 1
Message 2 of 2
Re: Using own router with FTTP
