7idge
Message 1 of 6
Using pfSense
Hi,
I was wondering how I set up pfSense with my Openreach modem. Do I use PPPoE?
Thanks in Advance
5 REPLIES 5
licquorice
Message 2 of 6
Re: Using pfSense
Username bthomehub@btbroadband.com
Password bt
7idge
Message 3 of 6
Re: Using pfSense
Thanks for the Reply,
Should I turn on "Dial-On-Demand mode" and should I put anything in the "PPPoE Idle timeout" box?
brookheather
Expert
Message 4 of 6
Re: Using pfSense
No leave it all at default.
licquorice
Message 5 of 6
Re: Using pfSense
VLAN ID is 101 if you need to enter it.
7idge
Message 6 of 6
Re: Using pfSense
Thanks for everybody's help
