Hi,
I was wondering how I set up pfSense with my Openreach modem. Do I use PPPoE?
Thanks in Advance
Solved! Go to Solution.
Username bthomehub@btbroadband.com
Password bt
Thanks for the Reply,
Should I turn on "Dial-On-Demand mode" and should I put anything in the "PPPoE Idle timeout" box?
No leave it all at default.
VLAN ID is 101 if you need to enter it.
Thanks for everybody's help
