imjolly
Message 11 of 18
Re: VDSL Broadband is 15% SLOWER than ADSL
I think @RobbieBaron was being over optimistic with 20mb connection as the dslchecker shows expected range 10/5mb and you are currently in that band at 6mb
which exchange and cab are you on as you deleted that part of header
hystrix
Message 12 of 18
Exchange CHARD Cabinet 13.
Not sure where that is exactly, but probably 1 to 2 miles away.
Edit: Found it - it's 1.3 miles away.
imjolly
Message 13 of 18
you are on a Huawei cab which may give you a small speed boost if DLM activates G.INP but would have thought that would have happened with 22 days connection time
I would try connecting to test socket and see if that give you an increase in connection speed
did you try quiet line test?
hystrix
Message 14 of 18
Quiet line test was quiet - I could clearly hear the voice.
RobbieBaron
Message 15 of 18
It's not so much the voice but the gaps between it. They should be silent.
hystrix
Message 16 of 18
The gaps were quiet.
pippincp
Sage
Message 17 of 18
Not quiet, silent.
hystrix
Message 18 of 18
I have now moved my Smart Hub next to the master socket connected with a 1 metre cable. I'm still not sure going from 10 metres to 1 metre cable length is going to make any difference when I am 2,000 metres away from the cabinet!
I will post back here in a week or two with an update.
PS: Quiet line test was silent. Tinnitus is your enemy with this one 😉
