HillHopper
Newbie
Message 11 of 12
Re: VDSL - Problems with network latency
Typical router stats for one day
Moderator
Moderator
Message 12 of 12
Hi @HillHopper
Welcome and thanks for your posts.
Sorry for the problems you're having with your broadband speed during peak times.   I have had a look at this but nothing obvious stands out.
I will need your details to be sure as the SVLAN you're connected to may slightly differ from the details you've provided.  Click on my username here >> RobbieMac << and you'll see our contact link underneath my profile picture.
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
