Sage
Sage
Message 11 of 12
Re: VDSL change of speed
Crosstalk does not occur at the ports it occurs in the cables especially the bundled pair cables used by telcos.
mrl200
Message 12 of 12
So an update:
Another engineer - same tester as others........................
Checked stuff as usual, left running for a bit. Theres a blip at 31m on one pair and 28m on the other (not used).
So off he goes and checks in the hole in the ground to find my pair, so eventually he does but it goes a strange way as he cannot find the end of the armoured cable.........
Then with checking drawings 31m is under some tarmac, which is where my DP is!! When they changed some duct they just filled over it.
So explaining to his boss that the drop on the 250m wouldnt be enough for crosstalk and with it suddenly disappearing he agreed that the track and trace team need to come out, I guess to verify that the new tarmac is infact over the old pit! Also this pit is running a 100 pair!!!
It feels like progress!!
