Message 1 of 13
VDSL - slow and frequent disconnections
Hi, I've had broadband from BT for years now, and it's always been good. But from January this year I started to get 'VDSL Link Down' 20 to 50 times each day. I phoned this in to BT as a fault in late January. Since then I have had 7 engineers visit. They have all checked the connections in the house, performed a quite test (if that is the correct term) and concluded that the fault lies outside.
This is now 'case managed' by BT - although I'm not sure what that means because it hasn't actually made any difference. The last engineer was last Friday. The disconnects are still the same (ie, many) but now my speed, when I am connected, is very low (16Mbps down, 200kbps up). It's practically unsuable.
I am at a loss as to what to do next. Talking to BT doesn't help, and I get the strong impression that they don't really care.
[I have a BT Hub 6. And it's FTTC]
Help.
Simon.
12 REPLIES 12
Message 2 of 13
Re: VDSL - slow and frequent disconnections
questions you probably have been asked before but to get some idea of connection can you post stats  advanced settings then technical log information
enter phone number and post results  delete number but leave exchange and cab  https://www.dslchecker.bt.com/adsl/adslchecker.welcome
if you try quiet line test is there any noise   dial 17070 option 2 should be silent and best with corded phone
Message 3 of 13
Thank you for such a quick reply! I have done the Quiet Line Test - and it sounded completely silent to me.
Message 4 of 13
as you say your speeds are terrible but interesting is the max attainable is just above actual and nowhere near expected range  have you tried using the test socket with a filter making sure there is no dial tone at any of your extension socket where in normal use or not
test socket behind master faceplate
Message 5 of 13
My Master Socket looks different from the one in the diagram. It says Openreach Mk4 on the front, and Master Socket 5C on the top. I don't see any screws that I can undo.
Message 6 of 13
Just unclip the front part, and the test socket is behind.
Test like this.
NTE 5C Test socket checkNTE 5C Test socket check
Message 7 of 13
Thank you Keith. I have set it up as requested, and reconnected. This is the stats now - upload is improved a bit - to 800kbps.20200406_TechLog_p3.JPG
Message 8 of 13
yes but your attainable is more in keeping with estimated range suggesting a problem with your master socket and/or your extension wiring
Message 9 of 13
OK, that's interesting. I don't have any extensions - this is the only socket, and was tested by several of the engineers who came out.
Would that also explain the many VDSL disconnects that I get usually around 20 - 50 each day (and strangely they are mostly between 8:30am and 5pm! A few outliers).
Message 10 of 13
@SimonKn
If you do not have any extensions connected to the extension block. then is most likely just a poor connection between the front faceplate, and the test socket. This is a very common issue.
Probably being disturbed by vibration as people walk by.
You can continue to use the test socket to prove whether that was the issue.
