robp77
Newbie
Message 1 of 4
VLAN disconnection on HH6 and TPLINK VR900
For the past 10 months I have been having ongoing problems with my fibre connection. I have tried both the HH6 and the TPLink VR900 and both seem to drop the connection on regular intervals. When they do we lose all connection to the outside world.
I have tried two routers, new line filters and cables from the telephone socket to routers. Nothing seem to stop the problem. It does it at random times and also when we pause Netflix and then press play again, this seems to trigger it to drop the connection. It can be quite infuriating.
Below is the error log for the WAN from the hub. This shows the past few days drop outs. Has anyone else had this problem? Maybe the router needs configuring or I have set it up wrong. Any help is much appreciated!
Thanks.
3 REPLIES 3
robp77
Newbie
Message 2 of 4
Re: VLAN disconnection on HH6 and TPLINK VR900
17:28:31
10 Apr.
:WAN: SENSING AUTO VDSL
17:28:00
10 Apr.
ptm0.101:VLAN VLAN_DATA connected
17:28:00
10 Apr.
:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
17:28:00
10 Apr.
:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
17:28:00
10 Apr.
dsl:VDSL link Up: Down Rate=60663Kbps
Up Rate=8477Kbps
SNR Margin Down=0.00dB
SNR Margin Up=3.00dB
17:25:53
10 Apr.
:VLAN VLAN_DATA disconnected
17:25:46
10 Apr.
dsl:VDSL Link Down: duration was 155 seconds
17:23:42
10 Apr.
17:23:12
10 Apr.
17:23:11
10 Apr.
17:23:11
10 Apr.
17:23:11
10 Apr.
dsl:VDSL link Up: Down Rate=60138Kbps
Up Rate=8487Kbps
17:21:07
10 Apr.
17:20:59
10 Apr.
dsl:VDSL Link Down: duration was 172 seconds
17:18:38
10 Apr.
17:18:07
10 Apr.
17:18:07
10 Apr.
17:18:07
10 Apr.
17:18:07
10 Apr.
dsl:VDSL link Up: Down Rate=61403Kbps
Up Rate=8488Kbps
17:15:49
10 Apr.
17:15:42
10 Apr.
dsl:VDSL Link Down: duration was 856 seconds
17:01:55
10 Apr.
17:01:26
10 Apr.
17:01:26
10 Apr.
17:01:26
10 Apr.
17:01:26
10 Apr.
dsl:VDSL link Up: Down Rate=61372Kbps
Up Rate=8600Kbps
16:59:09
10 Apr.
16:59:03
10 Apr.
dsl:VDSL Link Down: duration was 220 seconds
16:55:52
10 Apr.
16:55:23
10 Apr.
16:55:23
10 Apr.
16:55:23
10 Apr.
16:55:23
10 Apr.
dsl:VDSL link Up: Down Rate=60107Kbps
Up Rate=8415Kbps
16:51:08
10 Apr.
16:51:02
10 Apr.
dsl:VDSL Link Down: duration was 71650 seconds
Message 3 of 4
You have an intermittent line fault. Is there any noise on the line when you carry out a quiet line test on 17070 with a corded phone plugged into the test socket behind the removable faceplate of the master socket.
robp77
Newbie
Message 4 of 4
Hi, I need to get hold of a corded phone to do the test. That is tomorrows task. Thanks for your reply.
