Phil_Stark
Newbie
Message 1 of 2
Very LOW ping between laptop and BTHUB 5
Lately I've been having some game issues and really high PING.
I tried everything on my PC to reduce it but nothing has worked so far. Then I tried to ping my router and voila. Here we go:
Pinging 192.168.1.254 with 32 bytes of data:
Reply from 192.168.1.254: bytes=32 time=2ms TTL=64
Reply from 192.168.1.254: bytes=32 time=555ms TTL=64
Reply from 192.168.1.254: bytes=32 time=165ms TTL=64
Ping statistics for 192.168.1.254:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 2ms, Maximum = 555ms, Average = 181ms
Reply from 192.168.1.254: bytes=32 time=93ms TTL=64
Reply from 192.168.1.254: bytes=32 time=10ms TTL=64
Reply from 192.168.1.254: bytes=32 time=235ms TTL=64
Reply from 192.168.1.254: bytes=32 time=152ms TTL=64
Minimum = 10ms, Maximum = 235ms, Average = 122ms
I tried to google some advice for router settings but this HUB5 is just ... ugh.
Can anyone give me any advice what to do or try? thanks 🙂
1 REPLY 1
Liam_
Expert
Message 2 of 2
Re: Very LOW ping between laptop and BTHUB 5
I assume you are using wireless, what results do you get with a wired connection?
Should be in the region of 1ms.  (wired)
