scorch2500
Newbie
Message 1 of 4
Very Slow Upload Speeds
HI,
I'm having issues with Upload speeds dropping from my normal 10-12 mbps to around 1.5.
I stream games via Twitch for a living, so this is obviously not something I can afford to have happening.
Any help would be greatly appreciated.
Thanks,
James
3 REPLIES 3
Message 2 of 4
Re: Very Slow Upload Speeds
edit out your phone number as this is public forum and you may get more spam that you can handle
Message 3 of 4
Are you running on wireless or Ethernet?
if wifi then I would split the networks and select the channels manually
turn of smart setup if you have not already done that
scorch2500
Newbie
Message 4 of 4
It's running on Ethernet. I'm using a Netgear Router as an Access Point, but all the Router work is being handled by the Home Hub 5.
I've been running the setup for well over three months now with no issues, but over the last two weeks I've had it start dropping.
Resetting both router solves the problem temporarily, but only for anything from a day or two to 5 minutes or so.
I just ran a TraceRoute, shown below.
1 1 ms 1 ms 1 ms 192.168.1.254
2 * * * Request timed out
3 * * * Request timed out
4 28 ms 27 ms 20 ms 31.55.187.176
5 19 ms 22 ms 26 ms 213.121.192.88
6 23 ms 20 ms 19 ms 109.159.252.100
7 28 ms 20 ms 28 ms 195.99.126.109
8 * * * Request timed out
9 * * * Request timed out
10 * * * Request timed out
11 30 ms 28 ms 21 ms 176.32.106.39
12 29 ms 30 ms 27 ms 178.236.3.117
13 * * * Request timed out
14 * * * Request timed out
15 * * * Request timed out
16 30 ms 29 ms 29 ms 54.230.9.57
Finished
