WalterB
Message 11 of 11
Re: Very Slow Upload
Hi,
No other sockets that are connected, no extension wiring attached. The wire comes off the pole into a hole in the wall into the loft and goes to a connection box where the old extensions used to be attached, which made the box in the loft the first socket. After the extension where disconnected the junction box in the loft now only has one connection which now goes to the connection box where the filter is.
So you are correct there is an additional connection box connecting the external wire to the internal wire.
Regards
