Distinguished Guru
Message 11 of 12
Re: Very bad line noise on analogue phone since BT Infinity 2 installed
You mean like this?
Infinity SSFP
The extension sockets should be connected to where the red arrow is pointing.
If not, I'll try again 🙂
efelstead
Message 12 of 12
Hello again
A short note to thank everyone who offered solutions to my LINE NOISE problem.
Very much appreciated.
I followed up all the suggestions but was still left  with a very noisy line.
As a last shot I went out and bought a NEW HANDSET from Argos for £6.99 as a last resort!
To my amazement THIS WORKED and the line was suddenly ABSOUTELY SILENT - NO NOISE AT ALL!
I tested the line using the BT LINE tester (Dial 17070 and then press KEY NUMBER 2  for "Quiet line test"
and there was NO DETECTABLE NOISE.
The moral of the story appears to be "Don't ignore the obvious"
Best wishes
Edward
